JD 350B Gas, motor knock
dubielj
Post by dubielj » Tue Oct 19, 2010 11:16 am
Looking at purchasing a 350B gas, manual blade, which has a very bad knock when warmed up. Sounds like a rod bearing. Everything else seems to be in good shape, carriage, pads, sprockets, steering, clutch, transmission. Is it worth repairing if I can but it for scrap metal price ($7-$800) How hard is it to get parts for this motor? Is it possible to buy a used motor? I'm in West Central Wisconsin
Post by Lavoy » Tue Oct 19, 2010 3:15 pm
That is an excellent engine, parts are readily available, and that price is dirt cheap, get it home before he changes his mind.
Post by Stan Disbrow » Tue Oct 19, 2010 4:15 pm
Shoot, they've used that basic engine in all sorts of equipment from 1965 until now. Parts are like popcorn on the floor of the movie house. Like Lavoy says, grab and go! ;)
Later!
dubielj
JD 350 B engine noise
Post by dubielj » Thu Oct 21, 2010 4:02 am
Well now I think I'm looking for a motor replacement. Local mechanic started it to hear the noise, block has a hole in it now. Any chance of a complete engine or would I need to buy, block, crank etc.
Post by Lavoy » Thu Oct 21, 2010 9:05 am
I hope this happened before you bought it?
dubielj
motor noise
Post by dubielj » Thu Oct 21, 2010 5:31 pm
I haven't bought it. Trying to find out what I'd have to pay for a motor if one was available.
Post by Lavoy » Fri Oct 22, 2010 7:47 am
I would guess a good running engine at $1500-$2000.
dubielj
350 b engine knock
Post by dubielj » Fri Oct 22, 2010 5:58 pm
so is this the best place to advertise "Wanted; running gas engine for a 350B JD"
Post by Lavoy » Fri Oct 22, 2010 9:13 pm
Check with local tractor salvage yards as well, should be same engine as 1020.
Post by Stan Disbrow » Sat Oct 23, 2010 5:08 am
Yep. 1020, 1030, 1520, 1530 and several other numbers I can no longer recall all used that engine.
later!
Users browsing this forum: No registered users and 154 guests
