JD40c Final drive case seperation
Dana
Post by Dana » Sun Oct 10, 2010 1:02 pm
Tracks and sprockets are off, but I am having trouble with the draw bar hollow dowels, seems that I cant get the 5/8 cap screw in far enough to withstand the punch and hammer. Can these come out after seperation of case?
Next- I noticed that there are two holes on the forward leading edge of the final drive case(on both sides of crawler) that look like they should have bolts in them, but dont. Are they missing or are those holes for something else. Seems like a dumb question, but both sides are missing.
Brake band adjustment bolt?- In my manual it shows some kind of wrench, but on my crawler it appears that the adjustment is a star shaped nut head. Is there a special tool for this nut?, and will the case come off with out slacking the bolt?
Thanks again for all your help.
I am not much of a mechanic, but this is turning out to be quite rewarding.
cant wait to tally up the cost when I discover the need for all the parts.
Dana
Old and rusty, green, yellow & crusty.
Post by Lavoy » Sun Oct 10, 2010 4:42 pm
If you are pulling the final off, no need to remover the dowels, they will pull out of the drawbar.
Brake band adjustment is just a screwdriver.
Front holes are there because finals interchange from side to side.
Dana
JD40c finals
Post by Dana » Sun Oct 10, 2010 8:26 pm
Thanks for the info. on the finals. Tomorrow should be a great day if I can get the yolk made.
New question. Any trick to getting the lugs off of the sprockets. Right side went well, noticing the it had 6 lugs(!/2"-9/16) and three (7/8).
Thinking the other side would be as easy, I noticed that it only had the 6 lugs of which are so tight, I broke one off and rounded the next..So now I am in the market for a six point socket instead of the twelve point.
Tried heat, but didn't seem to make a differance.
Side note: I tried to turn the engine over and bent two push rods. Are you the parts man. I will also be needing an engine gasket set.
Dana
Post by Lavoy » Mon Oct 11, 2010 8:35 am
Impact wrench works the best on stuck bolts, but if you don't have one, smack each one with a hammer first, the shock may break them loose.
Let me know what you need for parts.
Post by Paul Buhler » Tue Oct 12, 2010 8:12 am
This thread may help with your sprockets. Good luck, Paul
http://www.jdcrawlers.com/messageboard/ ... php?t=5176
Users browsing this forum: jimmydiesel and 212 guests
