WORN BRAKE DRUM
silerra
WORN BRAKE DRUM
Post by silerra » Tue Mar 28, 2006 7:18 pm
HOW DO YOU TELL IF A BRAKE DRUMON A 1010 NEEDS REPLACED.MINE IS NOT WORN EVEN ACROSS THE FACE. DO I NEED TO REPLACE IT OR IS IT NO BIG DEAL.
ROCK
silerra
Post by Lavoy » Tue Mar 28, 2006 11:06 pm
Brake drum should be pretty much square, if not I would replace it.
JP
brake drum
Post by JP » Wed Mar 29, 2006 6:41 am
I put my brake drum on the lathe and it cleaned up like new. Very little material was removed. Use a carbide cutter.
