Driveway project with a 40C
JD40c
Post by JD40c » Mon Sep 06, 2010 10:41 pm
I'd been planning on adding a shop extension and decided to widen the proposed gravel pad to make a spot for our RV.
A few pictures of the progress:
The area before digging started (taken a few months ago):
Just starting to cut in with the crawler. Our whole property has a diagonal slant to it.
Earth is filling in part of the pull-through driveway that we had but never used. I already formed the bank with the 40C when this picture was taken:
Originally, the driveway looked like this (taken when we first bought the home):
Now it looks like:
Borrowed a very nice JD 2440 with JD 146 bucket loader from a farmer friend of mine. At the end of the project (3 days) it had only used 5 gallons of diesel and moved a lot of earth.
The project as of today. I have the area roughly leveled with a pile of earth left for final leveling if needed. Will be putting in a 6" gravel pad with 1- rock soon. When I backed the RV in, it was dead level. I couldn't believe it.
The crawler has done sterling work during this progress, but the #76 blade has got to go. It's heavy enough that it really unbalances the dozer if it has much dirt in it and I lift it. Makes grading very difficult.
1955 John Deere 40C 4-roller
Post by Lavoy » Tue Sep 07, 2010 1:35 pm
Did you find a cutting edge?
gus
Post by gus » Tue Sep 07, 2010 1:46 pm
I think you would find grading difficult with any small dozer. They just don't have a long enough "wheel base" to do it. Small bumps just get bigger.
Best grading is done by back blading with the liitle guys. :wink: I didn't know how easy grading was until I drove a long track D6. :shock:
Gus
JD40c
Post by JD40c » Tue Sep 07, 2010 6:36 pm
I found a couple vendors, Lavoy, but haven't ordered yet. Most have the edges in 5/8" thickness, or different hole patterns. Mine appears to be worn down by 3/4" which would explain the problems with cutting into the ground.
I think having two cylinders for the blade when the #61 blade only has one makes a difference too. The blade is pretty slow acting on my crawler. A single cylinder would be more responsive.
Post by Lavoy » Tue Sep 07, 2010 7:40 pm
If you strike out, I think I have a new Deere sub number for the cutting edge. I think in the $100 range.
JD40c
Post by JD40c » Wed Sep 08, 2010 7:14 pm
I'd appreciate hearing what it is. The nearest equivalent I can find doesn't use all the same holes and I need them in order to use the gauge shoes. Worst case, I'll have to drill or torch a set of holes.
Post by Lavoy » Wed Sep 08, 2010 9:00 pm
Shoot my an e-mail when you get a chance.
Users browsing this forum: No registered users and 157 guests
