jd450 clutch
silerra
jd450 clutch
Post by silerra » Mon Mar 20, 2006 6:07 pm
jd450 wont move forward or reverse would this be internal drive clutch or something else ? how big of a job to replace ? thinking of buying it price is right
Uncle
Post by Uncle » Thu Apr 27, 2006 9:45 pm
Pull the seat and the cover plate for the pinion. Start the dozer and very carefully put in gear.
If the pinion turns, the problem is in the steering clutches/finals.
If the pinion does not turn, problem is main clutch/reverser/trans.
I hope this helps narrow it down.
Brian
Users browsing this forum: No registered users and 183 guests
