Is there an adjustment for this? will the procedure for adjusting the brake band help?
THANKS ahead of time for your response!!!!
If the brake and the clutch are both slipping, it sounds like there could be oil leaking into the clutch housing. Have you looked in the clutch housing (and/or removed the drain plugs recently)?Paul45 wrote:I have a 350 loader. The right side brake band needs to be replaced so i have been making alot of left turns LOL for steering. i have now noticed that the right side doesnt drive the way it did, like the cluthes a slipping or worn out.
The Steering Clutch-Brake adjustment (if the 350 is built the same as my 450B) involves two linkages, and a stop screw between two actuators. The Brake adjuster functions like any car drum/shoe adjuster in that it accounts for break wear and affects when the brake picks up and how hard it pulls within the travel of the brake linkages and steering levers.Paul45 wrote:Thanks Ken, i was wondering if the adjust effected the clutch or just the linkage of when the clutch disengaged . I will try the adjustment.
Users browsing this forum: No registered users and 276 guests
