JD 440 (GM 2-53)
Post by JD440ICD2006 » Sun Aug 01, 2010 8:04 pm
DELO 100 40wt is the correct oil for the GM 2 cycle, 2 stroke diesels. This is Chevron's brand, and as you state other companies have a similar oil.
(CF-2)
tuney443
Post by tuney443 » Mon Aug 02, 2010 12:48 am
Or 30 wt. depending on the ambient temperatures.You certainly wouldn't want 40 wt.when it's 30* or lower outside.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
Post by JD440ICD2006 » Mon Aug 02, 2010 6:42 am
Good point!
The Detroit mechanics tell me that 40 wt is good for engines with "time" on them and as long as it is not very cold weather.
Specs do call for 30 wt on new engines. It actually calls for lighter weights with colder temps, but we do not get that cold here very often. Since there is no cab on mine, I do not run it when it is very cold.
But they also state that the most important point is to use the Delo 100 (or equivalent rated CF-2) and ONLY a single weight oil.
Users browsing this forum: No registered users and 211 guests
