Post
by Ray III » Thu May 27, 2010 8:02 pm
Thanks for posting so many pictures. Beautiful work you're doing.
Why couldn't the head be repaired?
MADJACK
Post
by MADJACK » Sat May 29, 2010 9:33 pm
Awsome and inspiring!
Thanks for sharing, great story with a happy ending for this little beauty!
Top Gun
Post
by Top Gun » Sun May 30, 2010 6:53 am
Thanks everyone. The head was damaged in one exhaust port from water coming in through the rotted muffler. It probably could have had a new seat put in but by the time I had all the machine work done on it, it would have been more $$$ than a new one.
I put the engine in yesterday.
Have a bunch of pics to upload of the rebuild and install. Hope to get that done later today.
Top Gun
Post
by Top Gun » Mon May 31, 2010 6:47 pm
Top Gun
Post
by Top Gun » Mon May 31, 2010 6:51 pm
I painted the short block and then put the new water pump on and hydraulic pump.
Top Gun
Post
by Top Gun » Mon May 31, 2010 6:54 pm
I installed the short block and then put the head on. Heat shield, fan, etc.
Top Gun
Post
by Top Gun » Mon May 31, 2010 7:00 pm
Top Gun
Post
by Top Gun » Mon May 31, 2010 7:02 pm
Front grille housing installed.
Top Gun
Post
by Top Gun » Mon May 31, 2010 7:06 pm
Post
by JD440ICD2006 » Mon May 31, 2010 7:35 pm
Enjoying the pictures, please keep them coming!
H-D
Post
by H-D » Tue Jun 01, 2010 12:00 am
Dude, you need to hit up the cable channels to pay you to produce a "Crawler Makeover" program! Seriously, you do BEAUTIFUL work!!!
Top Gun
Post
by Top Gun » Wed Jun 02, 2010 7:46 pm
You have mail. Have a pretty good list of things I need for the final drives.
Brett
- Site Admin
Post
by Lavoy » Wed Jun 02, 2010 8:45 pm
Just got it, you should have one back by now.
Thanks,
Post
by Ray III » Mon Jun 07, 2010 7:32 pm
Just an FYI, I just had my head renewed by a machine shop with exhaust seat inserts and it was only $220. You might want to hang on to that old head in case someone wants it.
My friend said I should have had the head cut down to raise compression and make more power. That was my first thought too when I took it off and saw how big the chambers were. Has anyone ever done that? What's factory compression ratio, 7 to 1?
Top Gun
Post
by Top Gun » Mon Jun 07, 2010 8:11 pm
New block heater.
When I took off the right side final drive housing I found it had about 2" of water in it over the years.
Left side release bearing holder bead blasted. Only had 25 years of rust on it from being left on the ground next to it.
The tube is wore out. I'll replace both of them.
This upper shaft was solid rust also. It cleaned up pretty well.
Users browsing this forum: Google Adsense [Bot] and 267 guests
