1960 440 ICD
- emichaelhaynes
The shutoff lever should be well above the projecting nut on the left.JD440ICD2006 wrote:It is not a choke but a fuel shut off. The only way to shut down a diesel is to either stop the fuel (or shut off the the air) since there is no spark like a gas engine.
I cannot tell from the picture if it is connected properly. Your service manual will explain it.
Kraker,
The fuel supply and return lines go to the injector. It is a mechanical injector that runs off the middle rocker arm and is controlled by the fuel rack.
When installing injector, do not tighte n
injector clamp nut to more than 20-25 ft-lb
torque as this may distort the injector an d
cause working parts to bind . The fuel pipes
should be tightened to a torque not exceeding
12-15 ft-lb to prevent damage to the seatin g
surfaces of fuel pipe or connector. The rocker
arm bracket bolts should be tightened to
a torque of 50-55 ft-lb when reassembling .
After installing injector, position injecto r
control racks and adjust the exhaust valv e
lash to the cold setting as outlined unde r
"Engine Tune-Up" in Section 40 .
SM-2028
You really need to get the manuals, they will answer almost all your questions.
Chuck
SM-2028
Chuck
Again, I have ordered the manuals. I'm asking questions because they have not arrived yet and the tractor is stuck in my yard and I'm trying to get it into the shop to work on it when the manuals arrive.
Now I blead the fuel system, but the rear cylender seems to still be getting air into the line. Any ideas on what could be causing this?
The KRAKR
Dead Cylinder
Well I fixed the dead cylinder problem, even w/o a book. Right about the time I got finished, the mail came and one of the 3 books I ordered arrived, just not the one for the engine. I'm pretty sure it has the upgrade pistons in it, being that I havn't started it in 3 days, and once I was done messing with the fuel system, 2 cranks and bam running like a top w/o ether.
The KRAKR
Well I was thumbing threw the book on the chassis, and decided that I would see if I could get the steering working. Did some adjustments on the clutches and, just like that it turns both ways, effortlessly. Also I fixed the radiator hose that was leaking, just had to remove the nose cone and hydrolic resivoir.
The only two issues that are left is the clutch pedal, which feels just like a free hanging pedal (not hooked to anything) and the brake pedal which starts to slow the crawler if I push it really really hard.
That's it for now.
That's it for now.
The KRAKR
- waterman28
I like the early bronco's, but I love my Yota's. I've got two, the big one is an 82 and the little one's an 83.
List of mods
82-
7" Sky Jacker easy ride springs (front and rear, no blocks)
3" body lift
High steer cross over steering kit with power steering
5.29 gears with a spool in the rear and a detroit soft locker in the front
dual cases
10.2:1 195 rwhp .40 over Keith Black HP 22r
HD Ceramic clutch
37 13 r15 Boggers
83
Lincoln locker in the rear with 4.10 gears
power steering (add on)
32 9.50 r15 TSL Swampers
List of mods
82-
3" body lift
dual cases
HD Ceramic clutch
37 13 r15 Boggers
83
The KRAKR
nice! got a 75 bronco with 302 and C4 automagic, 44 front 4.10s, hardened shafts and a lock rite. 9in rear with spool 31 spline shafts 4.10s also. 35in swampers. 4 superlift.
just rolled out of the shop 86 bronco with 460 C6 and 205. four link front suspension 9in skyjacker lift, leaf rear (get a four link later) 60s front and back 5.83s linkin locked, 39in boggers
keep wheelin, nick
keep wheelin, nick
KRAKR,
Just watching a couple of your youtube vids. Looks like a nice crawler.
In case no one has told you using the reverser like you are doing as a clutch is a BIG no-no. Get the clutch fixed before you total the reverser. You are only supposed to move the reverser handle with the engine clutch released and the machine not moving. The little ears on those small clutch linings may be toast the way you are shifting it. Last I heard it is close to a grand to replace those.
Chuck
Chuck
Users browsing this forum: No registered users and 226 guests
