lp14255
Post
by lp14255 » Thu Apr 22, 2010 6:51 pm
first i want to say thanks for everyones help on questions in the past that i've had , this is a great site. i have 1 350 dozer and the lifting cylinders for the blade are rubbing really bad against the top of the motor cover. what would cause this, it seems like its worse on the left side.
Post
by digitup2 » Thu Apr 22, 2010 7:05 pm
Don't panic they did that send a couple of photos .When the main pin bushings loosened up the rub rail in the hard nose took a real scraping over .Digitup.
lp14255
Post
by lp14255 » Thu Apr 22, 2010 7:22 pm
digitup2 wrote:Don't panic they did that send a couple of photos .When the main pin bushings loosened up the rub rail in the hard nose took a real scraping over .Digitup.
i looked at where the main frame hooks to the two lift cylinders ,i didnt see any bushings i thought maybe all the pins are worn
CatD8RII
Post
by CatD8RII » Sun Apr 25, 2010 7:24 am
How tight is the mounting for the main frame? If thats loose the whole assemble could be moving over.
Post
by digitup2 » Mon Apr 26, 2010 6:51 am
Yes it is so hard to tell with out photos can you post some ?.Does the blade have much side to side movement when lifted just clear of the ground ?.What hours are on this machine ? The main pins usually got a fair slop in them and I know my 350D has rub rails on the housing but I am not sure if the 350C did Deere did have rub rails as O.E. parts to weld on the later 450s but never really looked at the 350s but have noticed no two 450s have the same clearance some times they have all the paint on then various stages of rubbing and grinding .Digitup.
lp14255
Post
by lp14255 » Fri Apr 30, 2010 7:53 pm
looking futher into this i found that the mounting frames where loose and the bushings are bad on the c-frame . i replaced the bushings and put new bolts on the mounting frame and its like new , no side to side movement at all.
1969 jd350 crawler dozer
Users browsing this forum: No registered users and 246 guests
