420 carb flooding?
justjd420
420 carb flooding?
Post by justjd420 » Tue Apr 27, 2010 7:12 pm
Any ideas why carb is getting a steady flow of fuel? Fuel coming out of breather tube at carb.
Post by JD440ICD2006 » Tue Apr 27, 2010 9:04 pm
The float inside the bowl opens and closes a needle valve that controls the amount of fuel in the bowl at any given time. It can be a bad needle valve, a bad needle valve seat, or the float not adjusted correctly.
A new needle and seat are included in most carb rebuild kits.
Post by Stan Disbrow » Wed Apr 28, 2010 8:02 am
Usually this turns out to be a piece of dirt stuck in the needle valve. That means a manual cleaning.
There's supposed to be a screen inside the carb inlet, part of the elbow that the fuel line attaches to. They get clogged, and I've seen a lot where someone just snipped off that screen as a result.
So, now the dirt it used to trap gets to the needle valve and - stick city with gas wandering out of the air intake.....
Later!
Al
Post by Al » Thu Apr 29, 2010 7:13 am
Could be the float no longer floats. Sometimes they develope a leak. If it doesn't float the way it should it won't close the needle valve
1937 B
1959 440CI
1966 110
1973 140 H3
Post by Paul Buhler » Thu Apr 29, 2010 8:28 pm
Hi: Send me an email address, and I can send you an attached Marvel-Schebler and Zenith carb manual - I found it helpful when rebuilding my 420's carb. Paul
Post by Paul Buhler » Thu Apr 29, 2010 8:29 pm
whoops, use pm or send to: pbuhler@vermontel.net.
Users browsing this forum: No registered users and 219 guests
