got the 420 home
Willycoyote
got the 420 home
Post by Willycoyote » Sun Apr 04, 2010 6:36 pm
got the crawler and gave her a bit of a work out found a couple of issues. firstly the right steering clutches slip under heavy load , im guessing they need replacing. secondly the right brake band needs relining. the rear sprockets and chains lookvery good very little wear on them. i did notice there are no upper track rollers or any provisions for mounting them is this normal on a 420. and is there any other place other than john deere where i can get a service manual i have the original operators manual but it doesnt go into tear down info
PowerStroker
Post by PowerStroker » Mon Apr 05, 2010 7:09 pm
only 5 roller crawlers had the upper idler..
the service manuals come up on ebay once in a while...if you know your way around machinery these little crawlers aren't that ccomplicated.. you just have to perfect getting those bolts with 50 years of rust out :x
the steering clutches might only need to be adjusted.
hope this helps and good luck
Users browsing this forum: Google Adsense [Bot] and 327 guests
