350-C isolator springs
donnaldp46
I have the engine out because of a reverser problemand was wonder if I should change the isolator springs while I am at it?
The isolater seemed to make alot of noise at a idle before the other problem caused me to desassemble it. The isolator seems loss and you can turn it some before it comes tight. Is there specs for this and the springs ? I would sure appreciate any advice you can give . THANK YOU
