440 FRONT IDLER
440 FRONT IDLER
TRYING TO REMOVE FRONT IDLER FROM BRACKET , SET SCREWS ARE BROKEN AND I CAN NOT SEEM TO DRILL THEM OUT ANYONE ELSE HAVE THIS PROBLE ? WHAT CAN I DOO
LAVOY , HAVE ANY IDLERS WITH BRACKETS REBUILT IN GOOD SHAPE
I seldom have had good luck drilling set screws, I always weld a nut to the broken off part, and then usually they will back out.
I am pretty much wiped out of side brackets, I have 2 NOS front idlers left, that is it.
All of the aftermarket axles are gone, so that wrecks that idea as well.
I do have two rebuilt idlers and brackets on hand, but at this time they will have to stay with the 440 I am trying to sell. I guess if no one wants it, and I get enough requests for parts, I will kill it, but it is awful hard to kill one that I had been ratholing for myself.
Axles and seals are still available from Deere, I have seals for less. At sometime in the future, I hope to have new axles available, but no idea on when.
Side brackets might be current, but last I checked on one, maybe for 420, they were like $750 per side. There is a chance, maybe even a good one, that by late summer, I will have new front idler brackets available for BO Lindeman through 430, maybe even 440/1010. When I find out, I will post the info, but for now, nothing other than maybe Deere, if you are desperate enough to spend $1500 on a pair of idler brackets.
I don't have any new brake bands on hand, just sold the last I had on hand, but easy to get more.
I have new and used upper idlers on hand, depends on which you want.
I was also digging around and found some front idler brackets for 440/1010, I did not have enough time to bring them back with me, but can get them some other time.
