440icd
You might check Eastwoods site. They have some high-temp paint on exhaust manifold paint that's supposed to be bulletproof. Not sure what colors they have, probably silver and black. Check out http://eastwood.resultspage.com/search? ... aust+paint
1955 John Deere 40C 4-roller
Primer for john Deere yellow enamel
So I was reading the can it says, I don't have to prime for it , but when I brushed a little on It doesn’t cover all the way.
Also it says not to use lacquer thinner to cut it, isn't all the paint thinner the same stuff? Lacquer thinner???
Went to the local auto paint store, they said I could put down laquire primer underneath it.
What kind of primer did anyone use under there Deere enamel?
Help
Help
Scott in wa.
Paint thinner and laquer thinner are not the same. Laquer thinner is typically a mixture of polar solvents (ketones,alcohols, etc) while paint thinner is typically a mixture of non-polar solvents (petrolium "oil" based fractionates, toluene). Polar and non-polar solvents are typically immisible (they do not mix). Toluene is somewhat of an exception in that is misible with many polar and non-palar solvents.
I believe Deere has their own thinner for their paint, at least I have been told that. Not sure what is in their thinner, but if Deere sells a thinner, they have to provide an MSDS (Material Safety Data Sheet) on the thinner, if requested. The MSDS will tell you what is in the can.
Ya, What he said..........loljac wrote:Paint thinner and laquer thinner are not the same. Laquer thinner is typically a mixture of polar solvents (ketones,alcohols, etc) while paint thinner is typically a mixture of non-polar solvents (petrolium "oil" based fractionates, toluene). Polar and non-polar solvents are typically immisible (they do not mix). Toluene is somewhat of an exception in that is misible with many polar and non-palar solvents.
I just painted a JD 350 with the deerd industrial yellow. I had previously removed the original paint with a grinder down to the bare metal. I sprayed on several coats of the deere paint without primer like the can says and it came out beautiful. The deere paint was worth all of the $50 per gallon price. You definately want to use the deere thinner as others are not compatable. GOOD LUCK PAUL
JD Paint
Yes, use the JD paint. It is worth every dime. I have painted alot of JD equipment; green, yellow, black, and even red. I have never used a primer with JD paint. I have painted bare metal and rusted metal. The trick to JD paint is light coats of paint. The first coat needs to became tacky then do the second coat and the third. On the last coat add a little laqcuer thinner to the paint. This will give a nice finish and shine. Trust me this works great. Check out my dozer in the pictures on this site. It is labeled "nice 1010 dozer". Good luck.
Users browsing this forum: No registered users and 188 guests
