blower operation
frozen dozer
blower operation
Post by frozen dozer » Fri Jul 21, 2006 11:35 pm
can someone explian t me how the blower gets its lubrication. i removed my blower and found oil inside. is this normal. when i removed the blower i did not have any oil lines to remove.
hunter41mag
Post by hunter41mag » Fri Jul 28, 2006 11:02 am
If it did not have any external lines than it should have internal passages from its mounting area to the engine. Suggest getting a manual to verify.
Don
1959 440 IC
Post by Lavoy » Fri Jul 28, 2006 12:28 pm
I believe oil on the inside is not correct. Usually if a Detroit gets oil in the blower, it will cause the engine to run wild and blow up. The larger Detroits had a valve that can be shut to kill the air going into the engine to shut them down when this occurs.
There is an update on the blower seal, it may be worth you time to remove the blower and take it to a Detroit shop to see if it has the updated seals.
emichaelhaynes
Post by emichaelhaynes » Mon Jul 31, 2006 7:45 pm
yup,
oil in the blower ain't right but don't forget about that !#@@# oil bath air cleaner as a source. chances are you (and i) need the seals updated to the latest. it'd be a shame to go through all that trouble (and expense) and have the air filter do a number on your head. K&N makes some cute filters. haven't actually tried one yet but that's next on my list.
This one might work directly on the blower:
http://www.knfilters.com/search/product ... od=RP-5118
once i get my blower back on i'll double check dimensions and try one. stay tuned...
michael
pop pop
tilting an oilbath
Post by pop pop » Thu Oct 01, 2009 12:39 am
you guys have any luck with changing out the oilbath to the dry type filters?i would consider this only because i plan to do some steep climbing and oilbath might not be so good.
Users browsing this forum: No registered users and 20 guests
