Generator install
Doc in Vermont
Generator install
Post by Doc in Vermont » Sat Feb 04, 2006 8:45 pm
I have a 440 ICD. Had to buy a rebuilt generator for it thru the local JD dealer. They told me they'd polarized the generator. I mounted it on the crawler today and connected the white wire to the "F" terminal and the black wire to the "A" terminal. The ammeter showed it wasn't charging. I then loosened the nuts holding the black & white wires and the ammeter indicated it was charging.
What do I need to do to make it charge? Do you think it is polarized properly?
JD40c
Post by JD40c » Sat Feb 04, 2006 11:28 pm
When you say loosen, how loose are you talking? Still somewhat snug? or freely turning?
1955 John Deere 40C 4-roller
Doc in Vermont
generator install
Post by Doc in Vermont » Sun Feb 05, 2006 6:32 am
Freely turning nuts. The engine was running, the nuts were loosened and the two (connected) wires were showing sparks on the terminal studs.
Users browsing this forum: No registered users and 244 guests
