JD 40c Track Removal Question
Greetings!
This may be a marginally stupid question but... I am having trouble removing one of the tracks on my 40c - I cannot get the pin out. I cannot see that anything is holding it in place except maybe rust. Is the answer just lots of heat and a big hammer or might there be a more civilized way? Thought I should ask before I break something instead of after.
Regards, Dennis
Regards, Dennis
Dennis
1955 40C, 1957 420C, 1960 440IC, 1952 MTW, 1950 M, 1960 Mack B-30
40c track pins
I have just removed and reinstalled both tracks on my 40c and I made up a jig with long large bolts and pressed the pins out rather than trying to beat them, once it was set up it worked well Just used scrap stuff I had laying around and imagination good luck
49c track removal
I used 5/8" bolts and 1/2" steel and a large impact socket to let the pin move out and a 1/2" nut as a pusher Once the pin starts to move it comes out readily Hard to explain in print but I am sure you will figure it out
It also helps to leave the track pad on the link and remove the one on the next link, doing this still alows acsess to the pin and the pad holds both sides of the link to keep it from trying to spread when you hit it. This problem has gotten me on more than one ocasion, heat can also be required and in extreme cases you may have to cut the center out of the pin with a torch. However unless you are on the clock and need to make time on this I dont recomend that.
A master pin for a 450 or other newer machine is less than 100 dollars and with shop rates around 85-90 per hour we used to cut the pins if they fought to hard and save the coustomer some labor. I'm assuming time isnt a factor here and parts are somewhat tough to come by so its best to try to save it if at all posible. Heating the link will usually do it, another thing to watch out for is mushrooming the end of the pin if it dose mushroom hammer it back the other way and use a die grinder to clean the burr off.
good luck.
good luck.
Hi Lavoy-
Is this issue limited to the 40c, or is this true for a wider range of older crawlers?
Users browsing this forum: Google Adsense [Bot] and 295 guests
