555 Hydraulic return line filter
wjptcs
Post by wjptcs » Tue Aug 04, 2009 4:01 pm
My manual shows that my hydraulic return line filter is under the right side reservoir cover. However there is no trace that there was ever a filter in this location.
Is there another location that these filters were placed. I have looked through several versions of the manuals 555 and 555A and cannot locate the filter anywhere.
wjptcs
Post by wjptcs » Wed Aug 05, 2009 8:02 am
Update.
I noticed that my fill cap for the hydraulic fluid was on a plate that had 6 bolts holding it down and a spring loaded valve. Just for the heck of it I pulled those 6 bolts out and there was the filter attached directly to the underside of the fill cap. The plate and filter slide up and out of the tank as a single unit. There is a tube running up into it as well that must be the return line for the oil.
So far no 555 manual I have found, even has a picture that is close to what my hydraulic oil filter and filler cap setup looks like. Hope this info helps someone else out someday.
SEAL
Post by SEAL » Tue Aug 11, 2009 9:09 am
That sounds like it is the same as the 450.
Users browsing this forum: No registered users and 264 guests
