axle slop question?
axle slop question?
Just a quick one since my manuals are 3 hrs away right now.... I am putting new sprockets on a 40c and noticed a bit of play on the left axle flange. Off-hand is any play non-acceptable, or will it live with just a bit? I have not measured anything, only felt by hand. The old sprocket wore about 1/8" groove in the shoe/stop just foward of the sprocket. It feels like about 1/8" by hand- enough to feel it anyway.
I should add that one axle flange has 3 dowels and the other side uses 3 shouldered bolts. Dont know if it matters much...but shows somethings been changed out somewhere along the line.
sounds like y ou have some bad bearings. This is a common problem on these machines I have had two and they both had the same problem. The 440 I am working on now has the same issue. I would replace them if it were me. Take a large pry bar and put it on your frame rails. Put the other end on your sprocket and lift up. If you have 1/8" by hand you will have more this way. If you use the machine you will cause wear and tear on the drive gears in the final and they are big bucks to fix. Thats just my two cents. Good luck!
- Eric.MacLeod
loose axle
hello, i just went thru the same thing on my 420,on the back side of the axle there is a cover held on by two bolts, when i took this cover off i could see there was two bolts that was ready to fall out. i dont know how they became so loose other then wear and tear, i tightened the two bolts and the slop went away. not sure if thats the cure all but maybe worth a look. Eric
Re: loose axle
You can also shim the cap to move the bearings closer together, if there is still life on the bearings. Look at the ends of the rollers, if they have marks from rubbing on the flange of the inner race, they have gotten too small and you need new bearings.Eric.MacLeod wrote:hello, i just went thru the same thing on my 420,on the back side of the axle there is a cover held on by two bolts, when i took this cover off i could see there was two bolts that was ready to fall out. i dont know how they became so loose other then wear and tear, i tightened the two bolts and the slop went away. not sure if thats the cure all but maybe worth a look. Eric
- Eric.MacLeod
bearings
i didnt check the shape of the bearings, now i guess well it is apart i will put new seals and bearings in. i hope the axle doesnt need welding like some of the ones ive read about on here. to many projects not enough time.. Eric..
I am in the same boat as you now. My 440 has the same issue. While you have it apart check and see if the seal going to the clutches is bad. If there is oil on your clutches then it went out. Might as well replace those clutch discs because if you dont the machine will stop turning and you will have to tear it all apart again. I would buy the entire bearing kit and fiber clutches at least.
Good luck
Good luck
- Eric.MacLeod
clutch seals
hi jeff,, i have new metallic clutches, throw out bearings,brakes,bearings,seals springs and tubes, i have taken the part for the throw out bearing apart, greased the three balls up and replaced it with new spings. where are the seals? do the tubes slide into them? i must have overlooked them. i bought all new seals and bearings that go into the finals that are laying on my floor. except for the axles which i will get now. thanks if i missed some seals i would like to put them in.. Eric
Thanks for the tips. I pulled the cover off the inside of the final and checked those two bolts mentioned by eric and mine where loose also. I took them out along with the heavy washer just to get a look and put back together. I dont think they have anything to do with preload so I ordered a variety of shims to see if I can get things in spec. These are the shims that go under the two bolt cover on the inside of the final. .002, .005, and .010 acorrding to the manual.
It would be great if I can just shim back to spec (I think .003-.007?) but that is not usually how my luck turns out.
Thanks for the help!
Users browsing this forum: No registered users and 229 guests
