Re-installling the throw out bearing assembly in a 440 gas. Should the carrier that slides on the clutch tube be packed with grease inside, and if so, what kind of grease ?
Grease from the zerk fitting only goes to bearing, possibly there is another path for grease to inside of carrier that is blocked. . . . . . ?
Hesitate to put grease this close to a clutch . . . .
Thanks,
Buddy
440 clutch lubrication question
1959 440 IC
Users browsing this forum: No registered users and 228 guests
