420 Cluthes
420 Cluthes
Just got my 420 running after it sat outside with out running for nearly 20 years. I had to replace the right brake band since it was worn out. now i have a few problems left. First, the foot clutch will grind when you push the pedal, but it does not do it every time. Second the right side steering will also grind when you pull the lever. Last, something is wrong with my hydraulic pump. It is very weak. It wont lift the blade on the front at all. I dont know if it can be fixed or if it will have to be replaced. I don't really know that much about crawlers so thanks for any advise.
Users browsing this forum: Google Adsense [Bot] and 319 guests
