Repair to transmission case
CAR
Post by CAR » Mon Jan 19, 2009 8:17 pm
I tried my hand at brazing cast iron this weekend. I did some research and found that you need to pre-heat the part to around 500 degrees before making the repair. So I dropped my case into a 30 gal. drum and heated with my propane burner. Took about an hour and a half to get it up to temp. Made the repair then wrapped it in an asbestos blanket and let it cool over night. The next day I drilled and tapped the hole. I figure if it held up to tapping it should be O.K. Here's a couple of pics.
Before.
After.
Craig
Post by JD440ICD2006 » Tue Jan 20, 2009 3:46 pm
You do good work. You will never know it has been repaired when the paint goes on!
CAR
Post by CAR » Sun Jan 25, 2009 7:20 pm
Thanks JD440ICD2006,
I just hope it holds.
Craig
Post by Lavoy » Mon Jan 26, 2009 9:02 am
Craig,
The one thing I would suggest is to use the longest bolt possible, so it goes all the way in to the bottom of the original threads.
CAR
Post by CAR » Mon Jan 26, 2009 9:52 pm
I had about 4 maybe 5 good threads at the bottom, I'll have to measure but I think the bolt that's in there now will do the trick.
bulldozerman
Post by bulldozerman » Fri Mar 27, 2009 10:06 am
What exactly did you heat the part in that you got it up to 500 degrees
1958 420c 5 roller
1944 Farmall A
1960 Case 440L backhoe
CAR
Post by CAR » Tue Mar 31, 2009 11:18 am
I used a 30 gal. steel drum with a steel plate for the lid. I basicly made an oven out of it, I wrapped an asbestos blanket around the drum to help insulated it then used a propane burner to heat it up. If the parts that need repaired are small enough you can heat them in an oven. My propane oven will heat up to 500 degrees, not sure about electric ovens.
Craig
