My "new to me" 2010
Post by jtrichard » Wed Mar 11, 2009 12:56 am
sounds like the end cap on the trans cooler froze i had same thing on one of mine both ends froze before i bought it the caps are not avilable from jd and i could not find any wreckers with one i did find one from a privite party and one cap had been welded on it they can be brazed the gaskets are avilable from jd about 2 bucks each now the bad news i dont think you can get out with out pulling the front housing and the rad. first
cdndozer
Post by cdndozer » Sat Mar 14, 2009 5:14 pm
Nice crawler loader RedDirt!
RedDirt
Post by RedDirt » Sun Mar 29, 2009 11:52 pm
Yup the end cap on the cooler froze and cracked. Both ends of the cooler have been welded before. One end looks fine, the other is cracked and showing about 1/16" gap for about an inch along the circle of the thin part of the transmission oil cooler cap. This is Deere Part AT-16540 which looks like a scarce part. Looks like cast iron that someone welded poorly. I think I'll grind it clean and try to braze it from the inside unless someone has a better repair idea.
And yes the only way in is to pull the front housing, radiator and then get down to the transmission cooler.
Oh well this gives me an excuse to change all the water and transmission cooler rubber hoses. One less thing to go wrong later.
Also I found that there was no thermostat in the cooling system. That explains why the thing never warmed up and was putting out so much smoke.
New glow plugs really did a good thing on the starting. Couple that with getting the primer working it started right up. Now with a thermostat it should actually start and warm more like a diesel should.
RedDirt - 2010 Diesel Crawler Loader Drott 4in1
Post by jtrichard » Wed Apr 01, 2009 9:57 pm
i have two with the same crack they can be brazed from the out side you cant get them from deere any more but you can get the gaskets
Users browsing this forum: No registered users and 158 guests
