JD 450 HLR Transmission problem. tractor wont move.
Balldog
Post by Balldog » Tue Feb 17, 2009 12:42 pm
I was pushing with my loader and the tranny got weak and moved slow. I checked the tranny oil and it was low. The next day (cold weather) I filled up the tranny and tested the tranny. The tractor would not move at all. I tried every gear and HLR and nothing. I let the machine run for several minutes to warm up and still nothing.
Does anyone have any ideas?
Thanks.
Prime mover JD 450 G six way. Secondary mover 450 loader.
jdemaris
Re: JD 450 HLR Transmission problem. tractor wont move.
Post by jdemaris » Tue Feb 17, 2009 1:04 pm
Balldog wrote:I was pushing with my loader and the tranny got weak and moved slow. I checked the tranny oil and it was low. The next day (cold weather) I filled up the tranny and tested the tranny. The tractor would not move at all. I tried every gear and HLR and nothing. I let the machine run for several minutes to warm up and still nothing.
Thanks.
You've got several fundementals to check. I assume you don't really know if the trans is slipping or maybe just not turning. Your machine has a single-plate dry engine clutch that drives that HL-R trans. You also have linkage attached to the clutch pedal that can come loose and cause the HL-R to stop moving. Even one little roll pin in that linkage that can break and do the same.
Balldog
Post by Balldog » Sun Apr 18, 2010 7:13 pm
If all the linkages are in place, what should I look to check next? The oil level is good. I can shift the tranny gears and they grind slowly from 1234.
Users browsing this forum: Johntc23 and 230 guests
