I was pushing with my loader and the tranny got weak and moved slow. I checked the tranny oil and it was low. The next day (cold weather) I filled up the tranny and tested the tranny. The tractor would not move at all. I tried every gear and HLR and nothing. I let the machine run for several minutes to warm up and still nothing.
Does anyone have any ideas?
Thanks.
JD 450 HLR Transmission problem. tractor wont move.
Prime mover JD 450 G six way. Secondary mover 450 loader.
Re: JD 450 HLR Transmission problem. tractor wont move.
You've got several fundementals to check. I assume you don't really know if the trans is slipping or maybe just not turning. Your machine has a single-plate dry engine clutch that drives that HL-R trans. You also have linkage attached to the clutch pedal that can come loose and cause the HL-R to stop moving. Even one little roll pin in that linkage that can break and do the same.Balldog wrote:I was pushing with my loader and the tranny got weak and moved slow. I checked the tranny oil and it was low. The next day (cold weather) I filled up the tranny and tested the tranny. The tractor would not move at all. I tried every gear and HLR and nothing. I let the machine run for several minutes to warm up and still nothing.
Thanks.
Users browsing this forum: Johntc23 and 267 guests
