I ordered new seals from a local shop. I removed from my quil part number AM1717T, They crossed referenced this and sent me a Timken
472924. The seal is the right diameter O.D and I.D, but is much thinner and does not have the metal jacket on the inside that the old seal has. Can anyone tell me if I have the right seal? Thanks
Craig
Differential Seal
You can get any type of oil seal you want. It's just not going to happen by using generic cross-reference numbers. That is because they do not match seals exactly by all attributes - only by shaft size and lip-type. This has been done to cut down warehouse inventories and sell you a general "fits all" seal. You can get seals designed just like the originals or better. You just look through a compete seal catalog and pick the seal by all the attributes you want.CAR wrote:Thanks Lavoy,
Thats funny that they are so hard to come by. I say that because the seals for the finals are exactly like the old ones.
Craig
Timken would not be my first choice as they are selling National Brand seals. Different companies have different options available. Garlock was a very popular one back in the 40s-50s-60s for tractors. Chicago Rawhide another, plus many more. Those metal-backed seals are not hard to get.
Thanks for that information, unfortunatly I have already installed the seals, quill and steering clutch housing. Since this is not an everyday use tractor I should be fine. I'll just remember to order seals with all the attributes to get what I want. I did notice the spec. sheet was from Timken, so it looks like they still make that seal.
Craig
Craig
Users browsing this forum: No registered users and 244 guests
