2010 steering clutches
Ashell
Post by Ashell » Tue Feb 10, 2009 3:40 pm
After almost a years procrastination I have the track apart the discs and gauge are ordered. Does anyone have any advice from this point?
Thanks in advance
Alan
I dunno what I'm doin but I'm doin what I know.
196? 2010 with model 50 backhoe and Drott 4 in 1 bucket
Ashell
Post by Ashell » Thu Feb 12, 2009 6:11 pm
I am impressed I called Lavoy at 4:30pm (ohio time) on tuesday and recieved my parts at 1:30pm thursday. thank you for your help and for the information you share on the msg boards.
robotmaker
replacing steering clutches
Post by robotmaker » Fri Feb 13, 2009 8:12 am
I hope you have the maintenance manual. I just went thru replacing steering clutches and found that the hardest part was putting new cotter pins in the linkages for the throwout bearing. You have to be a contortionist just to GET into this area, let alone trying to hit a hole you can't see.
rj
JD 2010 Crawler # 42193, 6 way blade and ripper attachment
Ashell
Post by Ashell » Fri Feb 13, 2009 8:40 am
I do have a manual I think it is as old as my crawler and the steering clutch part seems to be the most worn. Is there any tips or tools you suggest for putting in the cotter pins?
TIA
Alan Shell
Stretch
Post by Stretch » Fri Feb 13, 2009 6:25 pm
I think the hardest part is getting the shaft out to replace the clutchs. :x Everything else is a piece of cake. :roll:
It took me longer to get shafts out than to go back together.
Stretch
2010C Dozer, 2010C Loader
Ashell
Post by Ashell » Fri Feb 13, 2009 6:42 pm
I bought a 5 lb slide hammer like my book shows I hope that will make it a little easier. Does anyone know off hand what size bolt I need to go into the end of the shaft?
TIA
Alan
Ashell
Post by Ashell » Mon Mar 09, 2009 3:50 pm
I am about ready to go back together I discovered when I broke it down that I need to have my brake relined. My question is can I put the clutches in and then put the brake band in as long as I don't put the housing back on? This would allow me to get the sprocket back on and the track back together while I am waiting.
Thanks In Advance
Alan
Stretch
Post by Stretch » Mon Mar 09, 2009 4:45 pm
If I remember right, I believe you can snake the brake band around the hub.
2010 brake
Post by jtrichard » Tue Mar 10, 2009 8:15 pm
it can be done but it is a total PAIN you might want to wait
