420C Roller Grease fittings?
handlebar99
Post by handlebar99 » Sun Dec 18, 2005 3:48 pm
What do you call the grease filttings on the rollers of a 420C? The manual references a "special grease gun furnished with the tractor". Where can I get an adaptor for a grease gun that will fit these fittings?
I just bought my 420C with a 90 loader & scarifier at an estate auction. It had been sitting in a barn for a number of years and the auction folks couldn't get it started. (Fortunately!) When I got it home I replaced the condenser and it runs like a champ. I have been having a ball rooting out the multifora rose thickets which have been taking over the pasture.
This is a great site -- I've learned a lot already -- thanx for hosting the site.
james gibbons
420 greese fittings
Post by james gibbons » Sun Dec 18, 2005 4:21 pm
handlebar i had replaced mine with regular fittings and use a standard grease gun ps im from neck of the woods originally kingston james in nc 420 crawler 90 loader
Post by Lavoy » Sun Dec 18, 2005 8:07 pm
They are called button head fittings. I have new hose and adapters, if you want one, $45 + freight.
JD40c
Post by JD40c » Wed Dec 21, 2005 9:26 pm
I bought a Lincoln pistol grip type grease gun from NAPA. With a button-head grease coupler from Lavoy, you'd be set. I'm also using the John Deere Corn Head Grease and it works great.
1955 John Deere 40C 4-roller
shinnery
Post by shinnery » Fri Jan 27, 2006 8:17 pm
My local Yellowhouse had the adapter in stock. It was less than $30.00 as I remember.
Tim_in_IA
Post by Tim_in_IA » Mon Oct 16, 2006 11:50 am
what diameter is needed? 5/8" or 7/8"? I have a 440, assuming they would be the same?
1958 440ic with blade
Jimmy in NC
Post by Jimmy in NC » Mon Oct 16, 2006 12:02 pm
My 420 is the smaller if I remember correct.
Jimmy in NC
Post by Lavoy » Mon Oct 16, 2006 1:24 pm
If it is on Lindeman, MC, or 3 roller 40, it is likely the 7/8", if 420 or later, then 5/8".
lavoy
Users browsing this forum: No registered users and 171 guests
