Help Timing without the timing tool AM-450-T
I was looking everywhere to find a timing tool AM-450-T like it says in the book. None to be found or the part # has changed or not looking in the right direction. I was dumped into this project and with a new rebuilt engine? I think. not to sure what they did. What I did and see is the oil pump was install wrong because the distributor rotor was off 90 degrees when i set it on "spark" on the flywheel with the rotor no where near #1 "90" off. The carburetor was pouring gas out of it, but the spark plugs were dry. This is what i did took the oil pump out align with the narrow side out when the oil pump back was back in. with TDC on the Compression stroke. Now the rotor is straight in the middle of the two heads. Is that close??? don't know. Now for the carburetor I didn't look yet. I think the float would be stuck down if it's pouring out. I just need help please. Start me in a direction.
Thank you
Thank you for the pic when I put it on spark and put to rotor just about to touch #1 and points just staring to open that's where my distributor is at. So that's good. I'm waiting for the weather to warm up a little before trying it out. -20f right now. I'll wait until it hits zero before i try it. I did try it but didn't start around -5f. But i took the carburetor off and cleaned it seems ok. but I put it on and tried it and it was still pouring gas out the bottom of it. The spark plug were dry again. Why would it be pouring out the bottom??? And dry on the spark plugs???
You might want to do a compression test. you need the suction to pull gas into cyclinder. Check for proper valve timing, if the oil pump was wrong maybe the cam is off too.
when choking the carb, during starting I always get a bit of gas to run out of bottom of carb, especiallly if it does not fire right off.
1949 MC
"If it ain't broke, don't fix it"
Correct Wiring
I am confused. You say the engine ran and backfired when the plug wires were reversed. Was it running on both cylinders or just on one? Rotating the distributor even 180 degrees will not change the order the cylinders need to fire. Unless you are running on one cylinder. Then you are 90 degrees out of phase.
If there is a question, pull the valve cover off. Rotate the engine by hand and look when the valves open and close. When #1 cylinder two valves are just between both opening and closing, turn the engine one more full revolution (line up a timing mark) and you should have the points just opening and the rotor pointing to that wire. If this is OK, then do the same trick with #2 cylinder and see if the rotor is pointing to its appropriate spot. If this checks out, install the valve cover and you are in time on both cylinders. After it is runing, you can make the fine adjustment on the timing.
Mark
Mark
JD 2010 Crawler with Loader
Thank you for the replies. It would back fire when the wires were correct and not run. When i crossed the wires it would run. I believe you are right that's it's 90 off and running on one cylinder. I took # 1 spark plug out and put a rubber plug in and when it blew out I now know it's on the compression stroke. I moved it back a little to TDC and now I'm draining to oil and turning the oil pump gear 90 degrees. I adjusted the valves on #1. I don't see a mark on the flywheel for 180 degrees to adjust the #2 valves. Not sure what this means "If this is OK, then do the same trick with #2 cylinder and see if the rotor is pointing to its appropriate spot."???
HI! something is not right . if you installed the pump as you stated with the groove parallel to crankshaft with with narrow part towards the outside of engine or tractor as book states then the problem has to be with the installation of the distributor. if everthing is off by 90 degrees, it has to be IMHO the installation of the distributor. If you want I can scan the ignition timing procedures and send them in a personal message.
Good luck
Good luck
1949 MC
Just a thought, did you check the distributor cap? Unfortunately there are a substantial number of parts dealers out there that do not understand that the Dubuque engines and the Waterloo engines with the vertical distributor do not use the same cap. Even though many of the aftermarket books will tell you they do, that is not the case. If you put a Waterloo dist cap on a Dubuque, you automatically have a one cylinder engine, the cap is oriented 89 degrees off.
Dhall-
I have found it easiest to post my pictures on a free online photo sharing site (I use Photobucket). Once posted, it gives you the path for the photos to paste into your post, using the
tags.
Users browsing this forum: No registered users and 300 guests
