pics of my 420c
420cbrett
pics of my 420c
Post by 420cbrett » Wed Dec 10, 2008 9:45 pm
Here are some pics of my 420c 4 roller, has new pins and bushings and good rails and sprockets.
[img]http://www.jdcrawlers.com/uploads/img_0170.jpg[/img]
[img]http://www.jdcrawlers.com/uploads/img_0172.jpg[/img][url]
What am I doing wrong, pictures wont post, could somebody help me out?
shinnery
Post by shinnery » Thu Dec 11, 2008 12:58 am
Trying also
I don't know what I did different, just clicked on the button, copied the text from your post and clicked the button again and did the preview thing and there they were.
Post by Tigerhaze » Thu Dec 11, 2008 9:43 am
Hi Bret-
The "URL" tag at the end of the second pic is what was causing you the posting problems. There should only be "IMG" tags.
stmftr395
Post by stmftr395 » Thu Dec 11, 2008 10:27 am
Brett; Nice looking crawler. Mark
420cbrett
Thank you for fixing the photos
Post by 420cbrett » Thu Dec 11, 2008 8:23 pm
I thought I was savy enough to figure out the posting procedure but no avail. Anyway, I am new to the jdcrawler scene, have numerous jd two cylinder wheel tractors but am thinking of moving them for more crawlers. Have located several assorted 40 and 420 crawlers dozers and loaders, just need time and money to try to gather them up. Dont know of many crawler enthusiasts in the north idaho, eastern washington area. Love this site and spend alot of time on it. Thanks again.
Brett
Post by Tigerhaze » Fri Dec 12, 2008 9:03 am
Hi Brett-
Just came through your area a couple of weeks ago- drove from Spokane to Libby, MT through Sandpoint. Really beautiful country- just wish they would finish the construction on US95 between Coeur D'Alene and Sandpoint!
Anyhow, welcome to the site.
Davie Sprocket
Post by Davie Sprocket » Sat Dec 13, 2008 2:59 pm
Cool pics i have the same holt blade on my crawler, is it possible to post some more pics of the blade as well as the hose setup om your crawler?
Dave
420C Holt Blade ROPS
420-40C Basket Case
420cbrett
Post by 420cbrett » Sat Dec 13, 2008 7:19 pm
[quote="Davie Sprocket"]Cool pics i have the same holt blade on my crawler, is it possible to post some more pics of the blade as well as the hose setup om your crawler?
Dave[/quote]
Dave,
Sure I will post or send you whatever you would like, you might give me a day or so. I can post them here or I can email you, tell me what you want focused exactly and I will try my best.
Brett
Davie Sprocket
Post by Davie Sprocket » Tue Dec 16, 2008 9:44 pm
Hey Brett
My crawler was very well used and the blade took a lot of that use. There is damage to the uprights, mostly were they are connected to the cross bars on the crawler, as well the hinge points and the rear anchor points have received a lot of repair. She was and is a work horse but she could use some tlc to get her back to pristine condition. Could you take some pics of around the blade and mostly along the mounts and hinge point. I have found it really hard to find any pics of these blades or any other info. Have a good one.
Dave
420-40C Basket Case
420cbrett
pics of dozer blade
Post by 420cbrett » Thu Dec 18, 2008 9:05 am
[img]http://www.jdcrawlers.com/uploads/blade5.jpg[/img]://www.jdcrawlers.com/uploads/blade2.jpg[/img]
I have alot more photos if you need them, if you want them send me your email address, I again cant seem to get pics to post.
Brett
57' 420c 4-roller w/ Holt dozer
55' 40c 4-roller w/m1000 tool carrier and dozer blade
Lu47Dan
Post by Lu47Dan » Thu Dec 18, 2008 1:39 pm
Lets see
Dan
1956 420C with GSC blade
cdndozer
Post by cdndozer » Thu Dec 18, 2008 7:08 pm
Nice dozer! :)
Davie Sprocket
Post by Davie Sprocket » Fri Dec 19, 2008 11:58 pm
Thanks Brett, that's what i was looking for and mine have had extensive work with the parts that bolt to the cross bars, i have them shimmed now but i will need to refab mine as they are bent pretty bad. I have the same rams, i'm going to keep them but i replaced them on the dozer with tie rod rams i got from the local princess auto. The 420c i have had a spill and it bent the rops as well as the blade so i think if possible i will try and straighten it out. Thanks to Dan for making the pics work.
Dave
420-40C Basket Case
Lu47Dan
Post by Lu47Dan » Sat Dec 20, 2008 12:15 am
Davie , you are welcome . Had a missing img and some extra bits in the link . Dan
Users browsing this forum: No registered users and 164 guests
