IslandCrawler
Post
by IslandCrawler » Mon Nov 03, 2008 1:20 pm
This is an old photo from when I just got the thing and was carrying out a complete inspection/maintenence of everything. I thought it would be fun to share!
As you can see it looks like the oil soaked earth being mined up in Canada!
The most frustrating part was trying to roll the wire mesh filter just-so that it would fit. The vertical position of the filter housing nestled inside everything doesn't help. I wish it had the replaceable paper element like other JDs.
JD 2010 Crawler Loader 7,500+hrs. and still ticking
Eric.MacLeod
Post
by Eric.MacLeod » Mon Nov 03, 2008 4:10 pm
did they use the air filter for plowing? the blade must look new! ha,ha . it must have run alot better when you cleaned it up, my filter was dented beyond repair im going to try a k&n fiter that the kids put on there cars, they look like a cone with a hose attached, i guess it will be better than none..thanks for sharing picture..Eric
dustin502
Post
by dustin502 » Tue Nov 04, 2008 12:35 pm
Eric, I wouldnt recommend using a K&N air filter. They allow alot more air to pass thru the filter but they also allow larger particles to pass thru as well. They work great For street applications. We got in about a dozen Harlan tow tractors a few years ago, they came with a cummins turbo 4cyl and K&N air filters. We had these tractors about a year before we started having trouble with the engines wearing out. The cylinders were worn very bad. After the second engine rebuild We changed to a traditional paper type filter and that seemed to fix the problem so far. Anyway just my thoughts on the subject.
57 Allis Chalmers D14
59 Allis Chalmers D14
Mustang 940 skidsteer
JD350B dozer
Eric.MacLeod
Post
by Eric.MacLeod » Tue Nov 04, 2008 3:07 pm
ok i will try a paper style filter i should be able to fab one up, i can even get a pre cleaner to put on top. thanks Eric
- Site Admin
Post
by Lavoy » Tue Nov 04, 2008 7:30 pm
A properly oiled and maintained K & N should out perform most paper filters. Maintenance is critical, as is proper oiling and cleaning.
Lu47Dan
Post
by Lu47Dan » Fri Nov 07, 2008 9:04 pm
I agree with Lavoy . The K&N filter I had in my truck went 117,000 miles , highway and farm miles , when I tore the engine down for rebuilding the cylinders still looked good (camshaft went soft at 217,000 miles). I have one on my Honda Fourtrax that has been cleaned and re-oiled every year since '93 and is still in good shape . A oiled cotton air filter actually works better if it is slightly dirty . Cleaning and oiling is the critical part of the equation . Once the filter is cleaned it must be completely dry before oiling . Use the proper oil when re-oiling the filter after cleaning .
Dan
1956 420C with GSC blade
- Site Admin
Post
by Lavoy » Fri Nov 07, 2008 10:22 pm
I've run them in every vehicle I owned since the mid 80's give or take, never had a problem. The one problem I did have one time was actually on a vacuum cleaner believe it or not. I bought a high end WAP Turbo vac and had it on my blast cabinet. It smoked the motor in short order. After a call to WAP, I find out that the numbnuts were not oiling the filter after they installed them from the factory, just the factory oil, and no recomendations to re-oil. Needless to say, they sent me a new motor free of charge.
Post
by Tigerhaze » Mon Nov 10, 2008 1:01 pm
I've used K&N filters for quite a while on my autos and trucks and I think they are great. K&N sells filter recharge kits that include their brand cleaner and oil- a little pricey but then you know the cleaner and oil is compatible.
Eric.MacLeod
Post
by Eric.MacLeod » Mon Nov 10, 2008 5:45 pm
o,k im going with my original plan ,k&n filter it is, it just seemed like an easy way to add a filter since mind was stove all to pieces, i think it went under the track at one point in its life, not looking to keep all stock just keep running. thanks all for input.. Eric
- Site Admin
Post
by Lavoy » Tue Nov 11, 2008 10:08 am
If you can, I would try and adapt the intake size to accomodate a larger filter. If you get one that will clamp right on the carb or the intake pipe, it will be a smaller filter, will much less surface area.
Eric.MacLeod
Post
by Eric.MacLeod » Tue Nov 11, 2008 11:52 am
im going to put the biggest i can buy on it, i figure home depot would have some pvc adaptors that i could make fit , ive built a few street rods from scratch so this should be pretty easy. although it wont be as fast as a street rod it sure will have more traction!! Eric
Tractor 850
Post
by Tractor 850 » Tue Nov 11, 2008 1:34 pm
Eric,
Let us know what your E.T. and top end are after the air flow upgrade.
Dave
JD440IC Ser#445235 W/ #63 Dozer
Ford 850 Ser#55497 W/Wagner Loader
Users browsing this forum: No registered users and 196 guests
