lift cylinder 831 loader
- john lewis
Hi next problem for me is leak on lift cylinder, see 2 o rings in parts diagram,are they what usually are bad ,or do u normally haft to go father down shaft to stop leak thanks john
440 ic 831 loader
- john lewis
- john lewis
- JD440ICD2006
The hardest part of rebuilding the cylinders in my opinion is getting the big net loose. You have to stabalize the shaft, but you cannot scratch it or you will create more potential leaks.
- john lewis
- JD440ICD2006
Not sure I would want to use heat, even though you are replacing all of the seals and O-rings. Others folks may differ.
The big nut that I am referring to is the one on the inside end of the ram rod. It can be a bear if it has never been off.
Users browsing this forum: No registered users and 407 guests
