jd350
jd350
I have a 350 that I just purchased, IT starts up runs good for about two or or three minutes then quits. The fuel filters were just changed but i replaced them anyway, i replaced the manual fuel pump and tried loosening the return line but still end up with the same problem. I'am hoping someone can help me.
Re: jd350
You didn't mention if diesel or gas, and if diesel - a C series injection pump or a D series injection pump.BVD wrote:I have a 350 that I just purchased, IT starts up runs good for about two or or three minutes then quits. The fuel filters were just changed but i replaced them anyway, i replaced the manual fuel pump and tried loosening the return line but still end up with the same problem. I'am hoping someone can help me.
350 diesel with D series pumps are prone to failure caused by a piece of plastic falling apart inside the pump. Symptoms are - it will run fine, then start to lose power, then quit. Let it sit a while, and it will then start fine, run good at first, peter out, and quit again.
Can be fixed in a few hours with less then $50 in parts if you know what you're doing. Otherwise you likely to spend $300 - $800 to get it fixed depending on who you send it to.
This is a D pump (DB or JDB) with the part that often fails:
This is the C pump that does not have that problem - however it's obsolete and no parts are available for repair
jd 350 starts than stops
The 350 is a diesel and you are right about the pump as i took it in and they said it had a disenagrated plastic part and repaired it for 600.00. Thank You for replying to my question. BVD
Users browsing this forum: Google [Bot] and 250 guests
