440icd steering clutch
jimmy
Post by jimmy » Mon Nov 07, 2005 6:31 pm
I' have the clutch apart (steering) and I think the throw out bearing carrier has dropped three balls and they were not letting the bearing release so no clutch hook up,any theory on this?The 440 never did turn left except when the handel was pulled real hard and the last pull was its last..also need master link for track
Post by Lavoy » Mon Nov 07, 2005 7:57 pm
If you are not careful when you put the throwout parts together, the balls can fall out of their cups, you most likely won't notice it.
jd440
Post by jd440 » Mon Nov 14, 2005 3:16 pm
Are the inserts (cups) used to seat the balls available anywhere? One of mine went missing during the clutch job on my 440IC.
Derek
Jimmy in NC
Post by Jimmy in NC » Mon Nov 14, 2005 7:55 pm
I just bought one for my 420c. Mother Deere has them.. a lil spendy if I remember correct.. (~$20-25) .. but I needed it.
jd440
Post by jd440 » Mon Nov 14, 2005 7:59 pm
Any idea what the part number is for the insert?
Thanks,
Derek
jd440
Steering Clutch Throw-Out Bearing Carrier Ball Insert
Post by jd440 » Thu Nov 17, 2005 10:54 pm
Has anyone tried to make an insert? I made one up from a piece of 1" round stock steel and a 5/8" ball endmill using a lathe. The height of the new insert is the same height as the original, and the height of the new insert with ball in place is the same height as the original with ball in place.
I'm just wondering if it will work.
Derek
Jimmy in NC
Post by Jimmy in NC » Fri Nov 18, 2005 6:52 am
Derek-
I'd be willing to say go for it. Alot would depend on the material that you made it from. The ball cups are chromed like a bearing race. I don't know if it's crome or what it is.. I do know it's stout material.
Jimmy in NC
Post by Lavoy » Fri Nov 18, 2005 9:14 am
I would have to agree with Jimmy. What ever they are, they are hard. If they start to wear, it will adversely affect the way the clutch operates. I have plenty of used ones if you need some.
jd440
Post by jd440 » Fri Nov 18, 2005 11:15 am
I think I will take you up on a used insert.
Do you also have a used throw-out bearing carrier? Mine has some cracks in it, and I'm concerned about the bearing coming loose. If so, can you give me a cost for the insert and carrier?
Thanks,
Derek
Post by Lavoy » Fri Nov 18, 2005 9:53 pm
Derek,
Send me an e-mail or PM, and I will check and see that I have everything here and get back to you.
Users browsing this forum: No registered users and 260 guests
