bolt size
Johnneypopper
bolt size
Post by Johnneypopper » Fri Jun 06, 2008 12:12 pm
hey all
i built a roller cariere for my 420 and each side is made to bolt on to the cross members but im stumped on the bolt size for the cross members 3/4 is to small and 7/8 is to big thats thread size the only standard size would be 13/16 wich i cant get any help would be great
Lu47Dan
Post by Lu47Dan » Sat Jun 07, 2008 10:28 pm
My parts manual list the jam nut for the bottom rollers as a 3/4 and the bolts that bolt the roller to the track frame as 1/2 " . If you are talking about the Idler wheel it lists them as same .
TIP ALERT : If you are having trouble determining a shaft size use open end wrenches to measure the diameter of the shaft . Nuts and bolts are measured across the flats not corner to corner .
Hope this helps . Dan
1956 420C with GSC blade
Johnneypopper
Post by Johnneypopper » Sun Jun 08, 2008 11:50 am
thanks dan
actually i was talking about the receiving holes on the ends of the cross members i had to retap them and they are 7/8 what i did was weld up a set of press drill wheels and bolted them to the cross members so im able to wheel the crawler around move it in and out of the way as needed
Users browsing this forum: No registered users and 341 guests
