Another part bites the dust.
Post by Lavoy » Fri May 30, 2008 9:23 pm
Got a call from a customer this week, it seems that the track stops for 420/430 are now obsolete, he got the last one in inventory. I would like to pursue making new ones, but I need a perfect used one, or an NOS one for a pattern. If someone has one they want to sell, let me know.
country53
Another part bites the dst.
Post by country53 » Sun Jun 01, 2008 4:57 pm
Please excuse my ignorance. What is a track stop?
Post by Lavoy » Sun Jun 01, 2008 5:39 pm
That is the little block that is ahead of the sprocket on the MC thru 430. The theory is that if you overload the drivetrain, the cushions around the crossbars will flex enough to let the sprocket contact the track stop. When this happens, it will slip the clutch or kill the engine. If you look in a service manual for one of these crawler, you are supposed to shim the block out to a given space between it and the sprocket. I highly doubt this got done much, and I seems to me the track stop is most often used to grind the teeth off of the sprocket when people run the bearings out of the final drive and keep using the crawler.
country53
Post by country53 » Tue Jun 03, 2008 4:57 am
Thanx for the info. My track blocks were worn through, I pitched them. I want to build me a set, but since I got my crawler done I can't seem to quit using it long enough to make it better.(unless something breaks)
Post by Lavoy » Tue Jun 03, 2008 8:42 am
See, that is why you need another crawler.
country53
Post by country53 » Tue Jun 03, 2008 10:23 am
I know I want one bad. Lookes at a IH TD-3 and a JD 1010. Can't justify, but still want one or two.
Post by Lavoy » Tue Jun 03, 2008 11:30 am
Your first mistake is trying to justify one, or two. or three, etc. I we had to justify these old girls, probably should sell them all. :D
Post by Stan Disbrow » Thu Jun 05, 2008 12:43 pm
I'll look thru my crates of leftover parts. I seem to recall having a couple new ones around. When our dealership closed, dad grabbed every 420 crawler part there was and put it into the barn. Worse comes to worst, I can always pull one off of my 420c and send it to you as I can't recall that we ever had the situation arise where they actually came into use. :)
What I *should* do is carry the old girl up to you, Lavoy, and have her completely rebuilt to as-new. That way, every odd part that's usually trashed but isn't on this one, you can use for a template! :P
Later!
Post by Lavoy » Fri Jun 06, 2008 8:01 am
Bring it up, should have an opening early to mid summer next year.
Lu47Dan
Post by Lu47Dan » Sat Aug 09, 2008 6:23 pm
Lavoy , did you ever get a good track stop for the 420/430's ? Reason I am asking is I will need two when I get back to working on mine both of them are worn through on mine :x . Dan
1956 420C with GSC blade
Post by Lavoy » Sat Aug 09, 2008 9:25 pm
Yes, I finally located an NOS one for pattern, now I just have to see about getting it cast. There is a foundry near me that will sandcast, but now matter how small the part, it is $100 minimum, so I need to keep looking.
Lu47Dan
Post by Lu47Dan » Sun Aug 10, 2008 12:19 am
I read on a site about a foundry here in Pennsylvania run by the Amish that would cast parts for old equipment , I will see if I can find their name and send you the information . Dan
Lu47Dan
Post by Lu47Dan » Sun Aug 10, 2008 12:49 pm
Lavoy PM about foundry sent . Dan
Users browsing this forum: No registered users and 202 guests
