Oil in reverser gettiing hot
eclark492
Post by eclark492 » Thu May 22, 2008 9:22 am
For Digitup or Lavoy,
I have a 1965 350 and the reverser oil seems to be getting too warm. If I put my hand on the stick after I run it awhile it"s almost too hot to touch. Otherwise it seems to work fine. Is it normal for it to run that hot.
Eclark
Post by digitup2 » Thu May 22, 2008 5:29 pm
This is almost always a sign of the Clutch plates sliping If your oil pressure is up them the clutch is wore out watch it close but it is the best news I can give you .Digitup.
jdemaris
Post by jdemaris » Fri May 23, 2008 3:12 pm
digitup2 wrote:This is almost always a sign of the Clutch plates sliping
Digitup.
Not necessarily true.
They all get so hot you can hardly touch them - once used hard for awhile. Never operated one that didn't, even when brand new.
Since we're dicussing imprecise terms here - "hot to touch" alone doesn't mean much of anything. Now, if it heats up unsually fast - or gets so hot it's going to reach the flash-point of the oil inside - then there's bad trouble.
A 350 reverser will get just as hot as the engine after awhile - there's nothing to prevent that. Try putting your hand on the engine after it's hot - and it's going to hurt too.
Flash point of the HyGuard oil (or equivalent) is around 458 degrees F. At 200 degrees F you won't be able to hold your hand on the reverser - yet at that temp there is no danger.
Lowest rated equivlanet to HyGuard still has a flash-point of 381 degrees F which is pretty hot.
Post by Stan Disbrow » Tue May 27, 2008 11:18 am
Yeah, hot to the touch means over 120 deg F, which really does not say much, does it? Time to get one of those cheap infrared electronic thermometers, I think, and come up with an actual temperature.
jdemaris
Post by jdemaris » Tue May 27, 2008 11:39 am
Stan Disbrow wrote:Hi,
When we were selling 350Cs new - our dealership had a 10 acre wood/dirt lot out back. Every crawler,backhoe and skidder we sold got run for a few hours pushing or moving dirt before it left. That includes new 350Cs and also any older machines we'd just repaired. I never ran a 350 that you could hold your hand on the reverser case after that workout.
Post by Lavoy » Tue May 27, 2008 1:31 pm
I have had the reverser case on a two cylinder crawler at over that temp after a long run on the dyno. In the world of modern lubricants, that is a low temp.
Users browsing this forum: No registered users and 207 guests
