Flywheel ring gear chewed up.
2010OWNER
Post by 2010OWNER » Sun May 13, 2007 9:44 pm
Gentlemen,
Due to a malfunctioning starter on my JD 410 backhoe, the teeth on the ring gear are about one third to one half gone on the starter side.
I have a new starter coming and plan to ignore the situation if it works.
I'd like to hear the comments of anyone who has encountered this before.
I don't want to be "stuck" somewhere with a backhoe that won't start. But I don't want to break the hoe in half to get at the flywheel either.
Thanks,
Brian
CASE
Ring Gear
Post by CASE » Mon May 12, 2008 5:52 pm
We used to remove the ring gear - turn it over and re-install - At least the gear would mesh better with the new starter gear - A little heat on the ring gear is required for easy assy.
Phil (mmmp)
Post by digitup2 » Mon May 12, 2008 6:46 pm
yes flip the ring gear if you do have a chance to split it 310s'310As and 410s are not that difficult to split.Shure start nice for years after too.Digitup.
2010OWNER
Chewed up ring gear
Post by 2010OWNER » Tue May 13, 2008 7:59 pm
Thanks for the replies. I"d have never thought of just flipping the ring gear.
It's been a year now and not a hint of a problem...So for the time being, I'm going to let sleeping dogs lie.
B.
'63 2010 Dozer, '44 Model B Tractor,'65 2010 Tractor, '55 40c crawler, '77 2240 Orchard Tractor.
Post by Lavoy » Wed May 14, 2008 8:01 am
If you are going to go to the work of splitting the tractor, I would install a new one.
Users browsing this forum: No registered users and 177 guests
