Stretch
Post
by Stretch » Fri May 09, 2008 5:02 am
I just found out the cylinder head on my 2010 loader is cracked in two places.
I am not having much luck finding another head.
I am considering having this one repaired by lock stitch.
Has anyone had one repaired before using this method?
If so, how did it do?
Stretch
2010C Dozer, 2010C Loader
jdemaris
Post
by jdemaris » Fri May 09, 2008 7:11 am
Stretch wrote:I just found out the cylinder head on my 2010 loader is cracked in two places.
Stretch
You didn't mention gas, LP, or diesel? Gas heads for 2010s are easy to find in good shape for $150-$200. Diesels are a different story since so many get ruined by ether starting. I know there are some 2010 diesel engines in tractor scrapyards - but condition unknown since the heads are still bolted to the engines.
If your's IS a diesel - you can expand your search to 1010s also - since 1010 and 2010 diesels use the same head - casting # T17514
In regard to welding your head - all depends what part of the head the crack is in.
FarmLife
Post
by FarmLife » Fri May 09, 2008 9:03 am
go to
http://www.locknstitch.com/ this is a professional cast iron repair company. Depending on where your cracks are this is a good repair method. There are also some good cast iron repair shops out there that can weld these, but some just can't be welded (as we found out with the head for our D. The guy we took it to specializes in cas iron repair and is totally stumped on why the weld won't stick.) Anyhow, I think the lock n stich method would be the best. Good Luck!
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post
by Tigerhaze » Fri May 09, 2008 11:56 am
I believe that Valu-Bilt has 2010 diesel heads (without valves) but they are pretty pricey.
Users browsing this forum: No registered users and 226 guests
