jac
Post
by jac » Tue Nov 01, 2005 7:13 pm
I have finally disassembled my right final drive. Gears are in very good shape. That is a relief. The main seal has worn the axle and created a recess on the axle shaft. It would except some wear but how much is acceptable?
Lavoy: part list sent as PM. Need 14 fiber and 12 metal clutch disks for the clutch kits
- Site Admin
Post
by Lavoy » Tue Nov 01, 2005 8:48 pm
A very littlel amount of wear is acceptable, the axle seal is a very tight fit. Another problem is the surface is rough and will eat up the new seal in short order.
Will check my PM's.
lavoy
jac
Post
by jac » Tue Nov 01, 2005 10:07 pm
OK, thanks. Did a quick measurement of the axle diameter and it looks like the axle is undersize about 0.049" at the seal. Quite a bit of wear.
- Site Admin
Post
by Lavoy » Wed Nov 02, 2005 10:16 am
See if you can find someone that can metal spray. They can cut the axle down, spray it back up and recut to size.
jac
Post
by jac » Wed Nov 02, 2005 10:25 am
What is the price for a used axle? Just in case. I have also heard about seal repair kits which use thin metal bands over the seal surface. The band is epoxied in place.
- Site Admin
Post
by Lavoy » Wed Nov 02, 2005 12:23 pm
I have tried sleeving axles in the past and have not been able to make it work. That is not to say that you could not.
A used axle that has been metal sprayed and remachined is $300. I do not believe I have one done, 2-3 week delay, my machinist is a 50 mile round trip from me.
Users browsing this forum: No registered users and 254 guests
