Hydraulics for a plow- John Deere MC
Looking to get a #44 JD plow for my MC crawler. The plow is hydraulic, however my MC only has the tool carrier hydraulics between the tracks. Can I splice into the hydraulic lines easly to make this work? Thanks
- FarmLife
- Contact:
you could tap into the pressure feed line and plumb in another valve going to a set of remotes on the back of the crawler.
But like Lavoy said, a set of shut-off valves on the tool carrier cylinders would be a less expensive way to go.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Users browsing this forum: No registered users and 21 guests
