550A Pinion shaft
Bobscooter
550A Pinion shaft
Post by Bobscooter » Thu Apr 17, 2008 7:16 am
I finaly found a pinion shaft,does anyone know why JD used bearings in some shafts,and bushings in others?My origonal shaft has a bearing,the one I found has a buishing what is the difference?
RANDY Fay
Post by RANDY Fay » Sat Apr 19, 2008 7:46 am
are you talking about ring and pinion in rear end of crawler?? there is no way a pinion shaft would last with just a bushing also ring and pinion are matched set and one can't be changed with out the other have fun Randy
Bobscooter
550A Pinion shaft
Post by Bobscooter » Mon Apr 21, 2008 7:44 am
NO,the final drive shaft in a 550A wide track T81196 shaft,some have a bearing some a bushing.The orignal that was in mine has a bearing the one I found has a bushing.Does it make a difference?
RANDY Fay
Post by RANDY Fay » Mon Apr 21, 2008 4:18 pm
I have never run into one like that--it looks as thow the bearing rides on the bushing I sniped a pic out of parts book if it will help it looks like it should work http://picasaweb.google.com/yasshol/550PinionShaft
have fun Randy
Users browsing this forum: Google Adsense [Bot] and 241 guests
