Mc lacks power in 3rd and 4th
My mc Starts up fine every time. It wants to stall out in 3rd or 4th until it is really warmed up. Even after warming it seems to be weak in these gears. It this normal? I was wondering if my timing my be off? Also my clutches require a strong pull. Can these be adjusted to be a little easier on the arms? Thanks
- FarmLife
- Contact:
we just got ours running pretty good and it just wants to stall trying to start in 4th, third gear it seems runs pretty strong. This is my first time playing one of the old vertical two-cylinders. I think the oil pump is a tooth off but not really sure. More or less I am really happy it is running this well!
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
The 440IC I'm helping a friend with had the advance mechanism stuck. The advance springs broke on disassembly to clean & polish, but the resident Harley guru pronounced them quite similar to Shovelhead equivalents post '70. We haven't got back around to trying yet...riding season is on us again. Oh yeah, this wasn't a Delco distributor & we don't know the difference between the Prestolite or the remaining option. The main point I meant to make is that you might want to check the advance function when you are setting the initial timing. These old machines will perform acceptably with the mechanical advantage of the lower gears, but really need the mixture & timing advace to be right to play in the higher gears.
Users browsing this forum: No registered users and 240 guests
