All the old Parts Catalogs are up on JDparts.com
Post by wwattson » Tue Apr 01, 2008 8:52 pm
Saw a post over on the johnnypoppers forum about Deere having put up all the old parts catalogs in PDF format. Funny, I noticed that the 1010C parts catalog was there in PDF a couple of weeks ago but I never thought to look any further. Sure as heck, they are all there. Downloaded the M, 40, 420/430, 440IC, and 440ICD Parts Catalogs tonight (the early tractors include the crawler versions). I hear all of the lettered tractors are there but didn't verify. Might save you some trouble looking.
Bill
Davie Sprocket
Post by Davie Sprocket » Wed Apr 02, 2008 12:53 pm
I tried to view the 420 and 40 catalogs and continued to get a corrupt pdf error has anyone else seen this?
Dave
420C Holt Blade ROPS
420-40C Basket Case
Post by Tigerhaze » Wed Apr 02, 2008 1:24 pm
Hi Bill- thanks for the heads up. Can you direct us to where on the parts site they are at? I quickly looked around and didn't see them.
Post by wwattson » Wed Apr 02, 2008 2:59 pm
Go to JDparts.com and select the John Deere Parts Catalog link. On the parts catalog screen enter the model number of the tractor and you will see a number of PDF links when the model search returns. Enter just the model nummber with none of the following letters as many of the older crawlers are included in the tractor configurations.
Post by wwattson » Wed Apr 02, 2008 3:01 pm
I forgot to add that the 2010 isn't up yet. I looked last night. You will see a note when the 2010 returns that it's not available. Pretty much the same as 1010 and 2010 parts.
Post by Tigerhaze » Wed Apr 02, 2008 4:52 pm
wwattson wrote:You will see a note when the 2010 returns that it's not available. Pretty much the same as 1010 and 2010 parts.
No kidding- I had a debate with the parts gal at my local Deere Industrial dealer yesterday- she couldn't accept that 2010 was a crawler model number until she conferred with some of her co-workers.
Post by wwattson » Wed Apr 02, 2008 4:57 pm
I feel your pain brother. At least I can make a 1010c sprocket if I need to. With a 2010c, you haven't even got that out.
Post by Tigerhaze » Wed Apr 02, 2008 5:04 pm
I happened to snag a set of Lavoy's NOS front idlers and sprockets- however they are the early serial number sprockets (smaller pin/bushing sprockets) so now I have to worry about availability of those rails, pins, and bushings!
Post by wwattson » Wed Apr 02, 2008 5:15 pm
I'd buy a set now and hold onto them. For the way most of us will use these crawlers, you might never wear out the ones you have and it's less likely you'd ever wear out two sets of pins and bushings.
I had my rails repinned last summer and I'm just about to the point where I can put them back on. I'm going to try to get the one piece welded onto my right side track frame tonight and then I've just got to finish the weld build-up from the idler wear and the track frame is ready to go back on.
Gotta love these old crawlers!
:wink:
Davie Sprocket
Post by Davie Sprocket » Thu Apr 03, 2008 10:15 pm
Found out what i was doing wrong, i was using firefox, you need to use internet explorer. After that i got the two i was looking for.
Dave
420-40C Basket Case
Users browsing this forum: No registered users and 307 guests
