Swampy,
My TSX641 after rebuild idled best at about 1/2 turn off the seat also. It is on a 420 engine. I have to watch mine because the idle screw will work its way out and if it is not idleing well I just have to turn it back in. Who knows how worn the seats are on these things after 50 years of messing with them.
Chuck
fine tuning 40c
yellowcrawler
Carburetor
An item to investigate that I experienced.
I had a TSX carburetor on another make of crawler, which I had to run very rich to keep it running. It had a removable venturi that was sucking air internally from the atmospheric vent on the bowl. Took me about a month to figure it out, sealed the venturi with old style Permatex gasket sealer, problem solved!
1960 440 ICD with 602 blade
1960 440 ICD with 831 bucket
1960 440 ICD with 831 bucket, center throttle
Jeff Clark
I am a new member and just aquired a 40c crawler ,sat for 12 years+ ran bad when it did run, I found the motor frose solid in the cylinders,did a rebuild for the piston condition, but what suprised the old owner was the govener bushings shot and the throttle plate missing one screw and the other loose ,had a croud of doubters but this engine runs great on stock tune settings ,regular gas, 10 year old plug wires ,sounds like something basic wrong.
Users browsing this forum: Majestic-12 [Bot] and 18 guests
