Clutch Throw-out Bearing Replacement
charless
Use of Reverser
Post by charless » Fri Jan 25, 2008 2:42 pm
If you were to keep the clutch depressed (disengaged) in your 440's would the reverser operate the machine....that is to say, move it backward and forward?
JD 440IC 2 CYL Gas Crawler Dozer with a 6 way blade. Serial Number 442495
Post by Stan Disbrow » Fri Jan 25, 2008 3:00 pm
I know about Jorde's, and I know there stuff is good, but I don't need to contact them for anything for myself. Since my wife has her own screenprinting and sign shop, I just make up my own stuff as I need it. Handy! :)
What I was thinking is that the reverser is a fairly rare item on a wheel tractor. They're more common on a crawler, although crawlers are far fewer than wheel tractors are. Anyway, after all that figuring, I figure that there might not be enough call for reverser instruction decals, so there's probably none available commercially these days.
So, I was asking if anyone knows of a commercially available replacement decal - and the original one on my 420 is, indeed, a decal and not a direct silkscreen print onto the metal like the yellow stripe, John Deere name and 420 number is.
If there's a commercial one available out there, I won't bother reinventing the thing. If there is not, then I'll make some up and send them to Lavoy for our use since we're pretty much the balance of old Deere crawler folks these days. :)
Well, I'll see if I can rope my wife into making up a screen for the decal, that is. I don't do that often enough to be any good at it. She owes me, though, since a couple weeks back I had to take some of my time and un-screw up what a paid (over $500) machine mechanic did to our main textile press while he was 'aligning' it. :P
later!
Post by Lavoy » Fri Jan 25, 2008 5:17 pm
I don't know if they are readily available or not. I think that Travis has them, I know I had one at one time, can't find it right now. I will do some digging and see if I can find it.
CELSESSER
Post by CELSESSER » Tue Jan 29, 2008 6:46 pm
Hey,
The decals are in the 440ICD Parts Book page 90-3.
T 1135T is the reverser decal It is about 3 inches square and the wording is as follows
IMPORTANT INSTRUCTIONS
DIRECTION REVERSER
DIRECTION REVERSER DOES NOT HAVE A NEUTRAL
POSITION. CONTROL LEVER MUST ALWAYS BE IN FORWARD
OR REVERSE POSITION.
CHECK OIL LEVEL EVERY 75 HOURS.
KEEP CLUTCHES ADJUSTED SO THAT A PULL OF
25 TO 35 POUNDS IS REQUIRED TO ENGAGE CLUTCHES.
DO NOT OPERATE THE UNIT IN REVERSE WHEN
THE TRANSMISSION IS IN REVERSE GEAR.
DISENGAGE MAIN ENGINE CLUTCH WHILE
SHIFTING DIRECTION REVERSER.
MAIN ENGINE CLUTCH
MAINTAIN CLUTCH ADJUSTMENT OF APPROX
1 -1/4 INCH FREE TRAVEL AT TOP OF CLUTCH PETAL.
Another one on that page is T 11749T Injector Caution is as follows.
CAUTION: THE ENGINE IN THIS TRACTOR
IS DESIGNED FOR AND IS EQUIPPED WITH
35 CU MM INJECTORS. INSTALATION OF
INJECTOR UNITS OTHER THAN THIS SIZE
WILL VOID WARRENTY AND WILL CAUSE
POSSIBLE DAMAGE TO TRACTOR.
Chuck
Users browsing this forum: No registered users and 263 guests
