Hello guys
The machine shop says the head is cracked
Haven't seen it yet
Could this be like a chevy small block in that it doesn't matter?
What is one worth?
there is a head shop 100 miles from here what should a fix cost me ?
The machine shop says it's not fixable
They maybe covering there a##
What other heads will work?
Lowboy
cracked head on 420c
Cracked heads are not uncommon on 420's. They normally crack between the valves, can not be run, they will take on water if you do. I have had some fixed by a shop about 60 miles from me, but what he does is a lost art, and real hard to find anyone that can do it anymore. Add to that the fact that most repairs are $200-$400 just for the repair, then the regular machine work comes later.
420, 430, and early 440 are the same.
I have heads if you need one.
420 c head
Hello guys
Took my head to a welding shop today
$65.00 to repair the crackAll totaled up with a cleaning and new seat it is 125.00 Guaranted for 12 months let's see if he's as good as he claims
Lowboy
Lowboy
Users browsing this forum: No registered users and 203 guests
