Valve clearance for 1010 diesel
Just picked up a '64 1010 4-cyl diesel. Doing the servicing now...anyone know what the clearance should be for the valves?
Best Regards
Rick
Best Regards
Rick
Yup Those # Are Right.... Does Your 1010 Run And Start Good??????? I Have One With New Sleeve Deck, New Pistons And Rings, New Valves And Head Job, Rebuilt Pump And Injectors... Over 3000.00 In The Engine And It Is A Bear To Start And Sound Bad..... I'am Still Looking For Ideas...... Good Luck......
Jeff
Jeff
Jeff,
Are your glow plugs all working, and are you using them every time? How long are you preheating before starting?
A 1010 diesel on an 80 degree day that has not been run that day will need to be preheated at least 30 seconds before it will start. If it has the primer attachment, it will say to give it two strokes of primer while preheating. Don't make the assumption that just because it is new and tight it will start without preheating.
We were using my brother's 1010 diesel this weekend. It was in the mid 80's here, and I preheated it for almost a minute and gave it two strokes on the primer, and it fired right off. This is not a new engine by any means, and I have started it without ether below 20 degrees by preheating and priming.
