Hi All
Great site you have here. I am working on a 450D dozer for a local farmer and put new steering clutches in it. The problem now is when I pull the lever for a left turn the engine bogs down but it does not do that with the right turn. This is with the machine in neutral and not moving. I checked the pressure at the spools it the plug in the cover and it has 200psi, when the right lever is pulled it drops to 0 but when the left lever is pulled it stays at 200.
Can anyone here tell me what the pressure readings should be and the proper method of adjusting the brakes and steering?
I have been enjoying the reading here on the JD's that I haven't seen in years. Now I am dealing with 700J & 750J dozers at work and some of that computer stuff can drive ya crazy. Thanks in advance for any help anyone can give here.
AL
JD450D Steering help needed.
- Contact:
I think your pressure is okay... Did you check the spool on the left turn to see if it is okay? Not broken? I had one of these do this same thing and the spool was broken in the middle. It appeared to be alright on the outside but it wouldn't move out and line up where it should. This caused the engine to bog down because the pressure couldn't release. You might also look for a restriction in a line somewhere. That's all I know... Sorry I can't help further.
- Contact:
Thanks to all that replied to this post. I found that the problem was when my friend cleaned the cover the spools fell out and he put them in on the wrong sides. The machines with lever steering use the same spool on both sides but the ones with pedal steering has a left and right spool that is different from each other. Dozer is steering fine now and the farmer is happy.
Users browsing this forum: No registered users and 474 guests
